It's all in the name! Well...it is for me when it comes to the Daytime Running Lights (DRLs). And the operative word for this neat little safety feature must surely be the term "Running". So here's my question:- why have the DRLs switched on when the car isn't "Running" (i.e. the car isn't actually moving)? Well it appears that the good Burghers in Germany have also considered this question and they have included a facility in the mk7 that allows the Handbrake to speak to the DRLs. What a clever lot they are in Germany!!
Turn-off DRLs when Handbrake is engaged
The instructions below describe how to implement a VCDS tweak that automatically turns-off the DRLs when the handbrake is engaged and then switches the DRLs back-on again when the Handbrake is disengaged. Grateful acknowledgement to the Stemei.de site for the original material.
Before proceeding, please consider any implications from this tweak on the Australian Design Rules and its application to vehicles fitted with DRLs.
1. Select 09 - Cent Elect. module control2. Select Security Access-163. Enter the magic access code. Click Do it! tab4. Select Adaptation - 10.
5. From the pull-down channel, select (5)-Daytime running lights- Tagfshrlicht-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten (it's about 10% down the channel list)6. In the New Value box, select active7. Click Do it! tab. Click Add to log to save a copy of the change and click Go Back tab
8. Exit from software
9. Test the facility by engaging and disengaging the handbrake (notice how the status of the handbrake modulates the operation of the DRLs)
I had a quick search but couldn't find it here. Has anyone looked into optioning the blind spot monitoring? I think it may be called "side assist" or "side view" surly the highline has all items required to make it work, I would imagine the little led on the side mirrors could be used as the warning indicator.
Andy: not sure that I have understood your question, but the mk7 Golf does have an option called "lane assist" . The advertising material from VW talks about lane-assist in terms of BSM. Is this what you are after? If so, the option requires that a forward view camera is installed (it's part of the rear-view mirror assembly, camera sits under the mirror-looking forward). This is not standard equipment in a Highline.
Hi all,
A while back I posted a problem trying to upgrade my normal MK7 Multifunction steering wheel to one that has tiptronic paddles. it's for a Golf 90TSI DSG comfort line.
I've tried Ross tech but they haven't been very helpful. I am hoping i have better luck here.
Summary:
I recently purchased a new VW OEM MFSW that has tiptronic paddles to replace my standard MSFW.
My mechanic installed the new MFSW and it seemed to work ok - i can shift gears with the MFSW paddles, and the other buttons seem to work ok.
However, there are 3 errors
1) EPC light on
2) Auto Stop/Start malfunction
3) Cruise control malfunction
Below are the scan results, any help will be much appreciated!
Thanks.
Code:Thursday,17,July,2014,16:26:57:23272 VCDS -- Windows Based VAG/VAS Emulator VCDS Version: 12.12.2.0 Data version: 20140212 Dealer/Shop Name: Beyond Limit Autos VIN: License Plate: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: AU (5Q0) Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F VIN: 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CXSA) Labels: 04E-907-309-V1.clb Part No SW: 04E 906 016 DF HW: 04E 907 309 A Component: 1.4l R4 TSI H08 5673 Revision: WAH08--- Coding: 01250032242405082000 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_ECM14TFS01104E906016DF 002002 ROD: EV_ECM14TFS01104E906016DF_VW37.rod VCID: 69D2115F88230A562C9-803C 1 Fault Found: 17149 - Check Coding of ECUs on Powertrain Data Bus P1647 00 [175] - - MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 14 Mileage: 2130 km Date: 2014.07.14 Time: 12:16:54 Readiness: 0000 0001 ------------------------------------------------------------------------------- Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb Part No SW: 0CW 300 046 A HW: 0AM 927 769 K Component: GSG DQ200-MQB H43 5113 Revision: 00043014 Serial number: CU501311195247 Coding: 0014 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_TCMDQ200021 001001 ROD: EV_TCMDQ200021_AU37.rod VCID: 3874841B830963DE637-806D No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb Part No SW: 5G0 907 044 T HW: 5G0 907 044 T Component: Climatronic H02 0805 Revision: 00001K06 Coding: 00120004200100001005000012101800 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_ACClimaBHBVW37X 003018 ROD: EV_ACClimaBHBVW37X_SE37.rod VCID: 3874841B830963DE637-806D Fresh Air Blower Front: Refrigerant Pressure And Temperature Sender: Air quality sensor: 1 Fault Found: 590081 - Control Circuit for A/C Compressor B10A9 11 [008] - Short to Ground Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 220 Mileage: 2024 km Date: 2014.07.11 Time: 15:27:49 ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: None Part No SW: 5Q0 937 084 AB HW: 5Q0 937 084 AB Component: BCM MQBAB B H16 0124 Serial number: 00011334600061 Coding: 03001842C24102F34BE44000000403081000000000000000000000000000 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_BCMCONTI 012001 ROD: EV_BCMBOSCH_SE37.rod VCID: 78F4441BC389A3DEA37-802D Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Component: WWS 131207 042 0551 Serial number: 131210032723 Coding: 0E4DDD Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB Component: RLFS 024 0042 Serial number: Y13M12D17H11M42S21S9 Coding: 00A8DD 1 Fault Found: 395273 - Control Circuit for Signal Horn B1344 14 [008] - Open or Short to Ground Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 229 Mileage: 2129 km Date: 2014.07.14 Time: 11:52:59 ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-294.clb Part No SW: 5Q0 919 294 F HW: 5Q0 919 294 A Component: PARKHILFE 8K H03 0142 Revision: -------- Serial number: 39331335202967 Coding: 0031151011 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_EPHVA18AU3700000 002024 ROD: EV_EPHVA18AU3700000_VW37.rod VCID: 3E789203A12D5DEEA9B-806B No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb Part No SW: 5Q0 953 521 P HW: 5Q0 953 569 A Component: Lenks.Modul 075 0135 Revision: FF027027 Serial number: 20131207500154 Coding: 0410 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_SMLSVALEOMQB 001015 ROD: N/A VCID: 3F86EF07A62754E6A2D-806A No ASAM data for: "EV_SMLSVALEOMQB" (VW37) No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb Part No SW: 5G0 920 861 HW: 5G0 920 861 Component: KOMBI 252 2210 Coding: 27A419082380000800082A00040000 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_DashBoardVDDMQBAB 008031 ROD: EV_DashBoardVDDMQBAB_AU37.rod VCID: E6C89A63193DA52E81B-80B3 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: None Part No SW: 5Q0 907 530 P HW: 5Q0 907 530 E Component: GW MQB Mid 124 1164 Revision: -------- Serial number: 0001355699 Coding: 030100342B085700EF0002481C0F00010001000000000000000000000000 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_GatewLear 010015 ROD: EV_GatewLear_AU37.rod VCID: 3E789203A12D5DEEA9B-806B Alternator: Multifunction unit control module: Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Component: E221__MFL-DC1 H14 0035 Serial number: 27130001231250063315 Coding: 2DFFFF Battery Monitoring Control Module: Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E Component: J367-BDMHella H03 8043 Serial number: 2415092103 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: None Part No SW: 5Q0 959 393 B HW: 5Q0 959 393 B Component: TSG FS 020 0025 Serial number: 03121302090098 Coding: 003003208001040000000000 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_DCUDriveSideEWMINKLO 006003 ROD: EV_DCUDriveSideEWMAXKLO.rod VCID: 3E789203A12D5DEEA9B-806B Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Component: FOND_FHSG_DRV 005 0005 Serial number: 00000000000001343624 Coding: 1D0000 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P Component: EPS_MQB_ZFLS 122 1043 Coding: 0103 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_SteerAssisMQB 010031 ROD: EV_SteerAssisMQB.rod VCID: 4182E9FFD0D32216D49-8014 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels: None Part No SW: 5G0 035 824 A HW: 5G0 035 824 A Component: MU-S--ER 040 0421 Serial number: V1E01412131694 Coding: 02730000FF00000011510001000900001F0100960100010001 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_MUStd4CPASE 002039 ROD: EV_MUStd4CPASE_SE37.rod VCID: 234E43772A8F1006A65-8076 Media Player Position 1: Subsystem 1 - Part No SW: 5G0 919 605 HW: 5G0 919 605 Component: ABT_Std_Radio H51 0022 Serial number: VWZ8Z9NJ702UNM No fault code found. End ---------------------------------------------------------------------
I posted this in the ECU section but didn't get any help, hopefully I can here;
I'm looking for someone in the Newcastle/Sydney area with a VCDS cable. I have a GTI PP and want to activate the Traffic alert system.
Any help appreciated. Happy to compensate people for their time.
Well to be honest, it might actually be activated and I just don't know. I don't live in a capital city (Newcastle) and I believe that traffic alerts only work in capital cities, so I've never had a chance to try it, I'm just assuming it doens't going off what other people on here have said and what the dealer told me.
It has been deactivated in the setting menu, however its easy to go in and tick the boxes (enable RDS, enable Traffic Alerts).
turtle: are you really sure that you don't have TMC activated? What year was your car built? Have you tried enabling "TP" and "RDS" on the radio menu and then waiting a little while to see if the list appears when you press the "TRAFFIC" button (you should also get triangles on the navigation screen)? And yes, you have to be in one of the Australian Capital cities for it to work.
DV52,
Because I don't live in a capital city, and haven't driven in one with the car yet, maybe it does work and I just don't know it yet. I know how to enable 'TP' and 'RDS'. I'll try it next time I travel to Sydney. My car is a MY14
Thanks for the input guys. Appreciate the help
