Page 23 of 198 FirstFirst ... 1321222324253373123 ... LastLast
Results 221 to 230 of 1974
  1. #221
    Jan 2014
    Burleigh Waters, QLD
    .....And yes, you have to be in one of the Australian Capital cities for it to work.
    ....or The Gold Coast — Australia's 6th biggest city.
  2. #222
    Quote Originally Posted by slashj View Post
    Hi all,
    A while back I posted a problem trying to upgrade my normal MK7 Multifunction steering wheel to one that has tiptronic paddles. it's for a Golf 90TSI DSG comfort line.
    I've tried Ross tech but they haven't been very helpful. I am hoping i have better luck here.
    Summary:
    I recently purchased a new VW OEM MFSW that has tiptronic paddles to replace my standard MSFW.
    My mechanic installed the new MFSW and it seemed to work ok - i can shift gears with the MFSW paddles, and the other buttons seem to work ok.
    However, there are 3 errors
    1) EPC light on
    2) Auto Stop/Start malfunction
    3) Cruise control malfunction
    Below are the scan results, any help will be much appreciated!
    Thanks.
    Code:
    Thursday,17,July,2014,16:26:57:23272
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.2.0
    Data version: 20140212
    Dealer/Shop Name: Beyond Limit Autos
    VIN:   License Plate:
    Chassis Type: AU (5Q0)
    Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
    VIN:
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    Address 01: Engine (J623-CXSA)       Labels: 04E-907-309-V1.clb
       Part No SW: 04E 906 016 DF    HW: 04E 907 309 A
       Component: 1.4l R4 TSI   H08 5673
       Revision: WAH08---
       Coding: 01250032242405082000
       Shop #: WSC 01357 011 00200
       ASAM Dataset: EV_ECM14TFS01104E906016DF 002002
       ROD: EV_ECM14TFS01104E906016DF_VW37.rod
       VCID: 69D2115F88230A562C9-803C
    1 Fault Found:
    17149 - Check Coding of ECUs on Powertrain Data Bus
              P1647 00 [175] - -
              MIL ON - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 2
                        Fault Frequency: 14
                        Mileage: 2130 km
                        Date: 2014.07.14
                        Time: 12:16:54
    Readiness: 0000 0001
    Address 02: Auto Trans (J743)       Labels: 0CW-927-769.clb
       Part No SW: 0CW 300 046 A    HW: 0AM 927 769 K
       Component: GSG DQ200-MQB H43 5113
       Revision: 00043014    Serial number: CU501311195247
       Coding: 0014
       ASAM Dataset: EV_TCMDQ200021 001001
       ROD: EV_TCMDQ200021_AU37.rod
       VCID: 3874841B830963DE637-806D
    No fault code found.
    Address 08: Auto HVAC (J255)       Labels: 5G0-907-044.clb
       Part No SW: 5G0 907 044 T    HW: 5G0 907 044 T
       Component: Climatronic   H02 0805
       Revision: 00001K06
       Coding: 00120004200100001005000012101800
       ASAM Dataset: EV_ACClimaBHBVW37X 003018
       ROD: EV_ACClimaBHBVW37X_SE37.rod
       Fresh Air Blower Front:
       Refrigerant Pressure And Temperature Sender:
       Air quality sensor:
    1 Fault Found:
    590081 - Control Circuit for A/C Compressor
              B10A9 11 [008] - Short to Ground
              Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 220
                        Mileage: 2024 km
                        Date: 2014.07.11
                        Time: 15:27:49
    Address 09: Cent. Elect. (J519)       Labels: None
       Part No SW: 5Q0 937 084 AB    HW: 5Q0 937 084 AB
       Component: BCM MQBAB B   H16 0124
       Serial number: 00011334600061
       Coding: 03001842C24102F34BE44000000403081000000000000000000000000000
       ASAM Dataset: EV_BCMCONTI 012001
       ROD: EV_BCMBOSCH_SE37.rod
       VCID: 78F4441BC389A3DEA37-802D
       Subsystem 1 - Part No SW: 5G2 955 119 A    HW: 5G2 955 119 A
       Component: WWS    131207  042 0551
       Serial number:         131210032723
       Coding: 0E4DDD
       Subsystem 2 - Part No SW: 5Q0 955 547     HW: 5Q0 955 547   Labels: 5Q0-955-547.CLB
       Component: RLFS  024 0042
       Serial number: Y13M12D17H11M42S21S9
       Coding: 00A8DD
    1 Fault Found:
    395273 - Control Circuit for Signal Horn
              B1344 14 [008] - Open or Short to Ground
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 229
                        Mileage: 2129 km
                        Date: 2014.07.14
                        Time: 11:52:59
    Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
       Part No SW: 5Q0 919 294 F    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0142
       Revision: --------    Serial number: 39331335202967
       Coding: 0031151011
       ASAM Dataset: EV_EPHVA18AU3700000 002024
       ROD: EV_EPHVA18AU3700000_VW37.rod
       VCID: 3E789203A12D5DEEA9B-806B
    Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
       Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
       Component: Lenks.Modul   075 0135
       Revision: FF027027    Serial number: 20131207500154
       Coding: 0410
       ASAM Dataset: EV_SMLSVALEOMQB 001015
       ROD: N/A
       VCID: 3F86EF07A62754E6A2D-806A
    No ASAM data for: "EV_SMLSVALEOMQB" (VW37)
    Address 17: Instruments (J285)       Labels: 5G0-920-XXX-17.clb
       Part No SW: 5G0 920 861     HW: 5G0 920 861
       Component: KOMBI         252 2210
       Coding: 27A419082380000800082A00040000
       ASAM Dataset: EV_DashBoardVDDMQBAB 008031
       ROD: EV_DashBoardVDDMQBAB_AU37.rod
       VCID: E6C89A63193DA52E81B-80B3
    Address 19: CAN Gateway (J533)       Labels: None
       Part No SW: 5Q0 907 530 P    HW: 5Q0 907 530 E
       Component: GW MQB Mid    124 1164
       Revision: --------    Serial number: 0001355699
       Coding: 030100342B085700EF0002481C0F00010001000000000000000000000000
       ASAM Dataset: EV_GatewLear 010015
       ROD: EV_GatewLear_AU37.rod
       Alternator:
       Multifunction unit control module:
       Subsystem 2 - Part No SW: 5G0 959 442 K    HW: 5G0 959 442 K
       Component: E221__MFL-DC1  H14 0035
       Serial number: 27130001231250063315
       Coding: 2DFFFF
       Battery Monitoring Control Module:
       Subsystem 3 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
       Component: J367-BDMHella  H03 8043
       Serial number: 2415092103
    Address 42: Door Elect, Driver (J386)       Labels: None
       Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
       Component: TSG FS        020 0025
       Serial number: 03121302090098
       Coding: 003003208001040000000000
       ASAM Dataset: EV_DCUDriveSideEWMINKLO 006003
       ROD: EV_DCUDriveSideEWMAXKLO.rod
       Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
       Component: FOND_FHSG_DRV  005 0005
       Serial number: 00000000000001343624
       Coding: 1D0000
    Address 44: Steering Assist (J500)       Labels: 5Q0-909-144.clb
       Part No SW: 5Q0 909 144 P    HW: 5Q0 909 144 P
       Component: EPS_MQB_ZFLS  122 1043
       Coding: 0103
       ASAM Dataset: EV_SteerAssisMQB 010031
       ROD: EV_SteerAssisMQB.rod
       VCID: 4182E9FFD0D32216D49-8014
    Address 5F: Information Electr. (J794)       Labels: None
       Part No SW: 5G0 035 824 A    HW: 5G0 035 824 A
       Component: MU-S--ER      040 0421
       Serial number: V1E01412131694
       Coding: 02730000FF00000011510001000900001F0100960100010001
       ASAM Dataset: EV_MUStd4CPASE 002039
       ROD: EV_MUStd4CPASE_SE37.rod
       VCID: 234E43772A8F1006A65-8076
       Media Player Position 1:
       Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
       Component: ABT_Std_Radio  H51 0022
       Serial number: VWZ8Z9NJ702UNM
    End   ---------------------------------------------------------------------
    I'm just having a quick look from my phone but it looks like the kilometers that the fault happened are logged with the fault. What km was the car at when you got the new part fitted?
    Have you tried clearing and see if they come back?
  3. #223
    Quote Originally Posted by flight View Post
    Flight: point well made! I keep forgetting about Gold Coast - not sure why.
  4. #224
    Apr 2014
    Does anyone know if there's a coding to allow the windows and roof to continue closing after the key is removed and a door is opened? It's a drag to have to wait till everything is closed before leaving.
    Greg
    MY14 Golf Wagon Highline 1.4L TSI 103, Limestone Grey Metallic, Roof, Leather, DAC.
  5. #225
    Apr 2011
    Wouldn't just holding the lock button achieve the same result?
  6. #226
    Quote Originally Posted by lambertia View Post
    Not sure, but if it's activated you should be able to do it with the remote by holding the LOCK button and the reverse will happen with holding the unlock ( windows open up) If you don't have the remote the same will happen by holding the key in the door lock in either the LOCK or UNLOCK.
  7. #227
    Apr 2014
    Yes the remote things work but they are slow. I want to start it in the car then walk away. My astra did this. O
    Of course I could try to remember to close them 30 seconds before I stop
    Greg
  8. #228
    Nov 2009
    The window and roof should continue to operate once the key is removed for up to (IIRC) 30 seconds, until you open the driver's door. That's how it functions in the Mk6. If you forget to close your windows and roof once you've opened the door, it'll take all of 10 seconds to hold down the lock button on the remote and have all windows and the roof close. Easy!
  9. #229
    Auto Rain Close -mk7 VCDS tweak
    EDIT NOTE: since I first wrote the instructions below- the forum community has learned much about this tweak. From this experience, it now seems that the success, or otherwise of the Auto Rain close facility is dependent on having the correct rain-sensor installed on the front windshield. Again from experience, it appears that the car MUST have a rain sensor with the part number 5Q0 955 547 WITHOUT ANY SUFFIX to be more likely to succeed. VCDS will report the correct sensor as RLFS, not RLHS. (thanks hadez16 & darkchina811 from RT forum)
    Background
    It's fair to say that the Auto RainClose tweak has had a dubious infancy when applied to MQB platform vehicles like the mk7 Golf. My understanding from conversations on various forums is that problems were first encountered with this tweak because of the new sensor that was installed in these cars.
    In previous models, VW used a "RLS" (i.e. Rain Light Sensor) to control Auto RainClose. However, in many of the mk7 models, the sensor that was introduced was the "RLFS" (Rain Light Humidity Sensor, or in German, Regen, Licht, Feuchte Sensor). Some VCDS auto-scan listings now report this new sensor as its Anglicized name, "RLHS" and of late, the RLS seems to have re-appeared in some mk7 scan reports (particularly in NAR cars).
    As a result of early problems with the Auto RainClose tweak, the folk at Ross Tech (i.e. the inestimable Dana) modified the VCDS software so that it would communicate correctly with these new sensor units. The first SW version in which these changes appeared was Beta ver. 14.6.1. At the time of writing, Ross Tech has advised that their Beta software (i.e. currently Beta 14.8.1) is still the only version with the necessary smarts to talk to the sensors on mk7 vehicles. Doubtless, in the fullness of time (to quote Sir Humphrey Appleby), RT's non-beta software will be modified to accommodate these new sensors.
    Edit - Nov 2014: Ross-Tech's full version software (SW version commencing with the number "14", or greater) is now able to fully communicate with the rain sensors in mk7 vehicles.
    The material in these instructions have been sourced from numerous forums and a skeletal version of these procedures can be found on the Stemie.de site.
    Particular acknowledgement is given to the findings of the folk on the VCDS thread on VWvortex. In addition, recognition must also be given to those talented and amazing VCDS gurus on the Ross Tech forum for unravelling the early problems with the RLFS. Thanks to you all for your valuable contributions.
    A word of caution for those that wish to proceed. This is one of the more complex tweaks and as a result, particular care and precision in following these instructions is required. Feedback from others indicates that a few have not been able to make this tweak work albeit I have received lots of reports of its successful implementation. If you fall into the latter category-congratulations. For those in the former category, please revert all settings to their original values (and re-check the entries for "opening and closing" in the Discover media screen which may have altered because of the factory reset process-see part 3 of these instructions). And, if you have implemented this tweak and you want to revert back to the car's original settings, make sure that you use RT's Beta software for the roll-back process.
    If others can add to the information in these tweak instructions, please do so. If you want to PM, I'll undertake to modify this post with any updates - or you can add your own separate post to this thread.
    For ease of understanding, these instructions have been broken-up into three discrete parts as follows (it is recommended that the instructions should be followed in the sequence listed):
    This Post
    Part 1: Auto RainClose - Coding Changes
    Post #230
    Part 2: Auto RainClose - Adaptation Channel Changes
    Part 3: Auto RainClose - In-Car, setup procedures
    All parts must be completed
    Ross-Tech software version commencing with a number "14", or greater must be used for this tweak
    1. From the Installed tab on the Select Control Module screen, select 09-Cent. Elect.
    2. On the Open Controller screen for address 09 - Cent. Elect., click the Coding - 07 tab
    3. When the screen below opens, click on the pull-down down tab in the middle of the screen (as shown next to the red arrow). As indicated in the picture, the BCM (Body Control Module) has two "slave" modules, one of which is the RLFS
    4, Select RLFS and click on the Long Coding Helper tab.
    Note 1: on some mk7 vehicles, the slave module will be RLS, or RLHS
    5. Select Byte 0 and place a tick in Bit 1 and Bit 2 as shown in the picture below. Exit this screen
    6. When the screen below appears, ensure that the New coding box contains the Hexadecimal value 06A8DD Click the Do it! tab. Go back to the open controller screen
    Note 2: some forums report "error 31" message at this point. If this error message appears, manually enter 06A8DD into the New coding box instead of using the Long Coding Helper. Then click the Do it! tab
    Note 3: On some mk7 vehicles, the default coding string for the rain sensor is 01E8DD. If this is the case, the required hexadecimal value in the new coding box is 07E8DD.
    Go to Part 2(next post)
  10. #230
    Auto Rain Close - mk7 VCDS tweak (parts 2 & 3)
    7. Once the Open Controller screen appears for address 09, click Security Access -16 tab
    8. When the Security Access window opens, enter the magic number for the Body Control Module as per the dialogue balloon (i.e. 31347). Click the Do it! tab
    9. When the Open Controller screen re-appears, click Adaptation - 10
    10 . From the pull-down channel menu, select (15)-Access control 2-Regenschliessen_ein_aus. and select active in New value box. Click Do it! tab
    11. Select (16)-Access control 2-Regenschliessen_art and select Permanent in New value box. Click Do it! tab
    12. Select (28 )-Access control 2-Menuesteuerung Regenschliessen and select active in New value box. Click Do it! tab.
    Note 4: this adaptation channel change adds "Automatic closing in rain" as an option-panel in the Discover Media menu screen (see Part 3)
    13. Exit the VCDS software and remove VCDS cable from the OBDII port
    Go to Part 3
    Auto RainClose - Factory reset procedure
    This tweak requires that the control unit be reset after the coding changes above have been made. This is done using the following steps:
    1. Press the CAR button on the RH side of the Discover media Unit
    2. Press the set-up panel on the bottom RH side of the screen
    3. Select Factory Setting panel (it's the very last entry on the list)
    4. On the Factory Setting screen, select Reset Mirror and Wiper Settings
    5. Press the Reset panel
    Auto RainClose -Menu enabling procedure
    For Auto RainClose to work, the function must first be enabled in the Discover media screen. This is done using the following steps:
    3. Press the Opening and Closing panel
    4. Place a tick in the Automatic closing in rain panel as shown in the picture below.
    5. Make sure that the settings for all other options (especially in Opening and closing) are appropriate and that they have not been changed by the factory reset process above (e.g. check that Convenience opening option isn't set to "off")
    6. Exit the screen
    source - 3askoul/www.Golfmk7.com
    Auto RainClose - Test and operating procedure
    1. Make sure that the wiper stalk is in the rain sensing position (i.e. up one position) and that the headlights are switched to the Auto position
    2. Wind down one, or more windows, and/or sunroof
    3. exit and lock the vehicle using the remote fob or KESSY
    4. Wait a minute, or two and pour water on the rain sensor, or tap the rain sensor with your fingers.
    5. The open window(s)/sunroof should close
    Note 5: a further feature of this tweak is that if the window(s)/sunroof is left open for an extended time (generally overnight) without rain, or intervention, the open aperture(s) will be automatically shut.
    Feed-back from forum members:
    Quote Originally Posted by sucnip
    Hi. I finally got the rain closing working over the weekend. I noticed that once I reset the closing settings I lost window up/down functionality on the remote. I had to manually wind each window up and down, restore auto up/down functionality before the remote started working again. Just thought I'd mention that in case you'd like to add it to the FAQ.
    Quote Originally Posted by Kiaorana
    one member mentioned he got this tweak working by changing the sequence order, he did 2,3,1.
