You would need to write a shell script or similar to do that. Quick Guide to Bash Shell Scripting
Okay maybe somebody can help me copy files across to my SD card... in folders.
I've now got Apple lossless and AAC versions of all my tracks in iTunes. Problem is finder (I use mac) sees every track as mpeg4 audio. Is there a short cut to only copy the AAC versions out of multiple folders and keep the folder structure?
I heard on the grapevine that the Mk7 MDI allows for video playback (when paired with a red collared ipod 30pin -not blue-, no word on compatibiliy with the lightning) from the iPhone, not sure if this is compatible with the Discover Media or if its a Discover Pro only affair.
As mentioned prior, retrofit options are becoming available. I thought I'd mention it to help people evaluate the purchase
MEDIA - IN MDI - Golf 7 5Q - iPhone / iPod
Hi guys,
This is my first post (other than the intro post). I pick up my 103 TSi Highline Golf on Friday and I have had conflicting reports from sales staff at the stealership regarding connecting the ipod to the car. I have a BMW X3 which uses the cable below to connect the ipod classic so that I can stream my music in apple lossless to the stereo. I have been told that it will work and I've been told it doesn't work. Does VW supply a similar cable and has anybody tried this and seen it work? Thanks in advance.
Steve
My MK6 uses a specific VW cable which plugs into the MDI in the centre console. Im assuming your Mk7 has been ordered with MDI (Media Device Interface)?
If so, then you will want the proper MDI to iphone cable. Golf Audi VW AMI MMI Media IN MDI Interface Adaptor Cable FOR Ipod Iphone Ipad | eBay
Any non Genuine cables do not work properly in my Mk6 - so im sure it will be much the same in the Mk7.
This is not a simple issue, according to another thread on this site.
Have a read through this: http://www.vwwatercooled.com.au/foru...olf-87352.html
Best of luck!
