Manual Mk7s are 1270kg, so you'd expect a Mk7 GTI to be at least that, possibly more with extra equipment maybe???
A DSG box weighs around 20kg more than a manual.
Mk6 GTIs weigh 1360kg (1380Kg DSG).
I didn't know the Golf was that heavy. My Jetta MK6 is 1.34 tonnes.
Don't forget the Mk VII is 'up to' 100kgs lighter, so it won't be 100kgs for every model. But I sure hope that the rumoured aluminium panels will make it to the GTI/R!
MkVI Golf GTI | Candy White | DSG | Leather | Bi-xenon | Sunroof | Dynaudio | Park Assist | MDI | Tint | FINALLY RECEIVED!!
I heard the GTI lost the most amount of weight. How much does XDL weigh (if anything), since this is being added to all Golf's but the GTI already had it, so that affects weight loss comparison.
Wake me up when the GTI and R are announced...
MY11 5 dr Golf GTI | White | 6Sp Man | MDI
Formally known as GTI_WRAITH
... when September ends?
Sorry couldn't help myself![]()
Not sure about the GTI but pretty sure all the golfs have an electronic controlled mechanical lock diff.
Really tempted to get the 2.0 GTD mk7 for my next car given the fuel consumption ratings. A theoretical range of ~1300km is equivalent to only having to refuel once a month at least for the distances that I cover on average each week. Hope all the speculation in the press turns out to be more or less accurate.
So, all cars (excluding electric cars with one motor per wheel and no common axle) have a mechanical differential. The Mk6 GTI and all MkVII Golfs will have XDL, eXtended Differential Lock, which despite the name actually has nothing to do with the differential, and is not a mechanical limited slip diff (although it's often compared to one), or a differential lock. It uses the ABS sensors (and possibly others) to detect wheel slip when exiting corners under power, and applies the brakes to the inner driving wheel to send more torque to the outer wheel, with more grip.
AFAIK, there's no plan to introduce a mechanical LSD (ala RenaultSport Megane RS, etc etc) to any of the MkVII Golfs.
