Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 73
Thread: Disable Stop/start - VCDS tweak
    Mar 2013
    Brisbane QLD
    Just disconnect the battery monitor unit plug on the battery earth lead....VDUB...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Dec 2008
    Sydney/Canberra
    Will it throw up lights on the dash?
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Mackay QLD
    The origin of Bambazonke
    Bambazonke: (interesting name!)
    Please let us know if the stop/start tweak works on your Tiguan.
    The indigenous nickname given to Salisbury the capital of the then Rhodesia where I was born
    It literally means "take all" like all capital cities around the world!
    MY 21 T Cross 85TSI Life| Makena Turquoise | Driver Assist Package |
    Mods: VCDS tweaks |
    Quote Originally Posted by Bambazonke View Post
    Bambazonke: Thanks for the information. I always like it when I learn stuff!
    Mar 2013
    Brisbane QLD
    Quote Originally Posted by Umai Naa!! View Post
    No it does not
    Quote Originally Posted by AdamD View Post
    You're more than welcome to copy and paste tweaks - people don't hold copyright over these things, and if they choose to share their knowledge in a public forum, then that information should be considered public.
    So by all means, create a VCDS Tweaks thread for the Mk7 if you like (we have this one for the Mk6: The Official VWW VCDS Tweak Library), but please provide as much detail (not speculation) as you can, along with any relevant links where readers may find more information. Also be sure to point out that any VCDS adjustments are made at the owner's own risk, and may result in damage to control modules, etc etc.
    AdamD. Thanks for the encouragement. I believe that VWW already has a place for VCDS tweaks at
    Forum/Specialist/VCDS Technical Resources/Vagcom Codes for Golf mk7. I was first introduced to this thread by the venerable Ryan_R.
    Last edited by AdamD; 26-02-2014 at 08:24 AM. Reason: Shifted VCDS content to VCDS thread
    Thanks guys, have turned off the stop start and works well...
    Any body found the coding to get the traffic or tmc working ... Can't find any thing anywhere...
    Also those links posted above are great...
    2019 MY19 Mini JCW Hatch
    2016 Holden Astra RSV - Waiting for New Golf
    Nov 2009
    Yep, that thread hasn't had much visibility so I've moved it into the Mk7 section for now, and shifted your post into it here:
    http://www.vwwatercooled.com.au/foru...ml#post1033967
    (Bear in mind that external links are only of use until a remote site goes down, is edited or otherwise changes to become less useful. It's also more difficult to quote remote references in context, so don't hesitate to post codes and suggestions in the above thread on VWW if appropriate.)
    Apr 2010
    Agreed. If you've got time get a copy of the codes/screenshots on these forums like I did for the Mk6. No-one has yelled at me for doing them
    (Just put a thanks/credit link to the source websites at the bottom).
    Melbourne, Vic
    Hi guys
    Im desperately trying to turn off start/stop on my caddy. however when i go into adaptation (mine actually says long adaptation) those channels aren't listed at all.
    i found some other areas that relate to this under engine, but if i do it via coding, it does nothing, and if it turn it off via engine adaption it just changes the value to active again.
    any thoughts??
    thanks
