Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 78
Thread: VCDS For 6R Polo (primarily GTI)
    Aug 2011
    I'm guessing it works fine with your Golf R32, which is also CAN based. I can only guess that your VCDS software is super old.
    Tried doing it with the key set to acc?
    Dec 2009
    Kew, VIC
    Quote Originally Posted by readerr0r View Post
    Depends on which unit you have — MicroCan (which I have) doesn't work with Polo, only with the Golf MkV and later.
    Polo (even the latest) uses an older system. I know of which I speak — tried it and failed.
    Hex-Can @ about $100 more is supposed to work fine.
    Mindarie, Perth (WA)
    Yep...works with the R32. VCDS software is latest ex Ross-Tech. V11.11.3. Might try it with key at "ACC" as opposed to "IGN ON"
    Quote Originally Posted by Idle View Post
    I have the Micro-CAN cable. Can't understand why it wouldn't work with a MY10.5 Polo (2010 6R TSI). the cable powers up when inserted in the socket (Green light comes on at CAN end).
    If I have to buy another cable...then I pass.
    Aug 2011
    Well I be, according to the Ross-tech guide you're correct. I knew the Polo 6R was based on the MK4 Golf but I assumed all the electronics would be up to Mk5+ spec seeing as it has MFD and whatnot.
    Luckily I grabbed a Hex+Can one
    http://download.ross-tech.com/VCDS/d...lityCharts.pdf
    Bar Stewards
    Aug 2011
    You can change the steering feel via VCDS as well. I'm currently on Program 21 (SEAT Ibiza) which has a heavier feel at slower speeds.
    Default for GTI is 41
    If you're after a constant weight to the wheel try program 20 (9N Polo GTI)
    If you want a super light city car feel try program 51 (Audi A1)
    (Copied from here)
    STG 44 Steering Assistance
    STG Codierung -> Channel 07
    ?xxxx: Airbag (See Notes!)
    0 = Airbags not installed
    1 = Airbags installed
    x??xx: Steering Angle Sensor
    01 = Steering Angle Sensor is Part of the Steering Aid
    12 = Steering Angle Sensor is Part of the ABS/ESP
    xxx??: Program Type
    10 - Normal (9N: PR L05, L06, L07, L08, L19, L20, L21, L32, L33)
    11 - Seat Ibiza (6J)
    20 - Polo 9N GTI (PR G12)
    21 - Seat Ibiza (6J)
    30 - Comfort (Polo 6R Comfortline)
    40 - Normal light vehicles (9N: PR L01, L02, L03, L04, L15, L16, L17, L18 )
    41 - Skoda Fabia 2 RS / Polo GTI
    50 - Comfort for light vehicles (Polo 6R Highline)
    51 - Audi A1 (8X)
    60 - Steering assistance for impaired (PR 1N5)
    VIC
    Is there any way to turn off the Bi-Xenon Permanent Running Lights?
    2010 Golf TSi & Polo GTI White MY12.5 - VIC
    Aug 2011
    If you want to take the Touchscreen Unit out of the Cradle but can't because the it shuts down the bluetooth. Or if your iPhone is cutting out playback on the MDI when the bluetooth connects, try these.
    *You only need to do VCDS coding if you want nothing in the cradle or using a non-VW branded Bury cradle*
    ie. If you get another VW-Branded phone specific cradle, you do not need to do any coding. But if you get a cradle from Bury (who make the cradle system), you will need to code it.
    To deactivate the touchscreen warning, first make sure your phones BT is off. It'll reject the coding if its connected to something.
    Load up VCDS -> Select Control module -> 77 - Telephone
    In Telephone go select coding and enter...
    0200000000000010
    To deactivate A2DP (which stops the iPhone cutting out on MDI) and touchscreen warning enter this code instead.
    0200000001000010
    Jun 2008
    Ringwood, Victoria
    Quote Originally Posted by syd View Post
    Yes, but don't understand why you would when it's one of the defining features of the car, but that's just me. Not sure where it is located but the dealerships can do it so I'm sure VCDS can.
    Readerr0r, you beat me to copying your discovery!
    Aug 2011
    Quote Originally Posted by gavs View Post
    You let the cat out of the bag when you reminded me of this forum
