Results 1 to 10 of 13
Thread: Gearbox shudders on down change.
    Nov 2009
    Epping, NSW
    I have a 2.0 FSi automatic MK V Sportline. When in drive and slowing down the gearbox is very clunky as it automatically changes down gears due to the reducing speed (mainly 3rd to 2nd and 2nd to 1st).
    Has anyone else had this problem do you know what needs to be done to fix it?
    Thanks.
    Aug 2011
    Yep, I did !!!
    Sorry for the bad news.
    Get it into a transmission specialist (or VW themselves) ASAP.
    I recently had the very same issue with my 2005 Sportline, it's tiptronic transmission had a failed valve body, the end result was a $4700.00 bill.
    According to the two specialists I spoke to this is VERY common, common enough to ask VW for some sort of good-will assistance imho.
    Some of my repair costs were covered by an extended warranty from the dealer I bought the car from, VW wouldn't help me unless it was inspected by one of their own dealers/service centres (fair enough).
    Is your car under any kind of warranty?
    Apr 2010
    Mine used to do it but it was an engine mount that needed replacing - you could fell the engine move which felt like a clunk each time it downshifted at low speeds.
    Oct 2012
    Melbourne, VIC
    Mine was doing the same, especially when trying to slowly cruise in 2nd or reverse up an incline. I had the mechatronics replaced under statutory warranty (mine was also one of the defective valve units from factory) which has fixed the violent shudder but is now doing a slight shudder as I drop down from 3rd to 1st. I had a VW tech drive it a couple of months ago after the mechatronics was replaced and he explained that the "clunk" sound and feel through the brake pedal was "normal" and just the selector within the box. At this point though it wasn't shuddering.
    It's due for a service in a month so i'm going to have it checked out then and hearing the good news of the updated 5 year driveline warranty it should be fixed up with no drama's.
    Could the shudder be the clutch pack rather than mechatronics unit?
    Jun 2007
    Guys, just so the OP gets the information he is seeking, he is not referring to a DSG transmission, his car is fitted with a conventional auto.
    George
    06 Jetta 2.0TFSI Killed by a Lexus!
    09 Eos 2.0TSI DSG Loved this car but has now gone to a new home!!
    14 EOS 2.0 TSI has arrived!
    Oct 2012
    Melbourne, VIC
    Ah good pick up! Apologies.
    As fatherless said, valve body issues are extremely common with the 6 speed tiptronic transmission (not dsg).
    The best thing to do would be get it to an auto transmission specialist for evaluation.
    MKV Golf 2.0 TDI DSG Sportline. Just nice.
    Nov 2009
    Epping, NSW
    Quote Originally Posted by stickshift3000 View Post
    As suggested above, I spoke to an auto transmission specialist last week. He concurred with your coments ....... It is a common problem. I simply said "I've got a Golf and it's making clunking noises in the gearbox as the auto changes down as I slow down". He then said, "about 70,000 km's on it?" I answered, "yes 68,000". He then asked "it gets worse as the motor warms up?" I said "I dont drive it enough to notice its the wife's car." He said "its the electronic shifters in the gearbox, common problem, approx $2,000 - $2,500 to fix.". Amazing hat a gearbox with less than 70,000 kms on it needs $2,000 - $2,500 spent on it.
    Thanks for the comments guys.
    Aug 2011
    That's actually good news, cost me a lot more (as you know).
    Did you try VW themselves?
    Nov 2009
    Epping, NSW
    Quote Originally Posted by Fatherless One View Post
    No I didn't try VW. I don't have any warranty so figured that would be a big number. 2 dealers in Sydney quoted me $2,200 - $2,500 for a major service (car had 50,000 km's on it but was 6 yrs old) and I got it done through a mechanic on here for $1,100 so figured the quote for a VW dealer would be about double again.
    Car went in this morning. Mechanic rang at lunch time and asked if they could keep it till tomorrow.
