Mine was not cooling much. Tested - low on gas. Regased - tested still low on gas.
Compressor not generating pressure difference. Assumed the worst: compressor failed (known problem on R32) sensing metal thru whole system. Quoted in Brisbane - up towards 4-5K to get all sorted.
Purchased new compressor, condenser, drier and special OIL ($400!!!) for compressor.
Swapped the lot - working fine. Parts shipped from BMA in USA, costed about $1000. Another $500 labour...
Working OK till date. I suspect that all that failed was a presure bypass valve on the AC compressor. As I taken old compressor apart and hound no mechanical issues....
.:R32T, Stock Internals | C2 stage III hardware | Schrick 268/272 | SRI by UM | DSG & Engine Code by UM | Side mounted oil cooler
