Page 6 of 29 FirstFirst ... 4567816 ... LastLast
Results 51 to 60 of 283
Thread: VWW Official MKIV Wheel Q&A
  1. #51
    Any one else have some decent pics at stock height or lowered on stock wheels?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  2. #52
    Wollongong, NSW
    I'll get some over the weekend
  3. #53
    Melbourne, VIC
    Finally here are the Supernovas I got from Dylan a while ago still need more more but they are on there way.
    Car: FWD
    Rims: Supernovas 5x114.3
    Front: 17x8 et25 with 20mm adapter GT Radial 215/45/17
    Rear: 17x9 et27 with 15mm adapter Hankook 225/45/17
    Arch height front: 614mm
    Arch height rear: 617mm
    Front:
    Rear:
    The daily
    White 2001 Mk4 GTI
    GIAC stage 1 - ECS stage 1 clutch & 14lbs Flywheel - 42Draft/Remus Exhaust - APR R1 dv - N75J - K&N
  4. #54
    Mar 2009
    Wagga Wagga
  5. #55
    Looking good!
    Hope your happy with the fitment.
    Would love to see white colour coded centres, polish the lips and bolts
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  6. #56
    Sep 2012
    Wonga Park, VIC
    Car: FWD
    Rims: Denvers 5x112
    Front: 17x7.5 et51 with 25mm adaptec hub centric adapters
    Rear: 17x7.5 et51 with 30mm adaptec hub centric adapters
    Stock ride height (for now...)
  7. #57
    Fill out the template as others have done dude, otherwise its a bit pointless for the purpose of this thread.
    Spot some Adaptec adapters :p
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  8. #58
    Sep 2012
    Wonga Park, VIC
    Done and done, yes thanks for the recommendation, very easy set up and the 25/30mm combo works great
    I couldnt find specifics for torque ratings for the adapter so i torque'd them to 120Nm (90 ft lb), that sounds right???
  9. #59
    Awesome. Do you mind throwing a tap on the ground to arch distance before you lower, just for refrence.
    Also I thought those were 7.5s? And rubber size? Sorry just want to get it all down.
    Ummm I forget the torque settings. I need to check that out, I just go by what feels ok... Whoops
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  10. #60
    Sep 2012
    Wonga Park, VIC
    Yeah no stress mate, will edit post with some more comprehensive details when I'm home and free next and your correct, 7.5 haha, cheers
