Page 10 of 29 FirstFirst ... 8910111220 ... LastLast
Results 91 to 100 of 283
Thread: VWW Official MKIV Wheel Q&A
  1. #91
    Jul 2013
    Western Sydney
    Hi,
    Hope I'm posting in the right spot.
    Got a 2002 Bora V6 4Motion and want to put some new shoes on it.
    I'm thinking of a set of BBS CK in 18x8 with an ET of 35. Just want to confirm that they'll fit without problems.
    With the right tyres rolling circumference change will be negligible, which I think should leave my lowering options open.
    Am I on the right track?
    Thanks
    Craig
  2. #92
    Quote Originally Posted by Craig S View Post
    Hi,
    Thanks
    Craig
    Yep, exactly what I started thread for.
    Sounds pretty good Craig.
    If I recall from your first post you were looking at doing lowering springs?
    18x8et35 will work fine at stock height and a bit of a drop.
    225/40 is your best bet for tyres.
    can also look at 235/40s. these are a bit bigger then OEM rolling diameter, but can be had a bit cheaper some times due to being common on falcons and commodores.
    I'm sure there should be some 8et35 wheels listed in the opening page if you want to have some idea oh how they will sit.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  3. #93
    Jul 2013
    Western Sydney
    Thanks Dylan,
    Yep, looking at some springs from an S3, which I'm told should do the job. Not sure how much lower it'll drop it, but I can always swap it back.
  4. #94
    I cant remember if the S3 springs are lower, or if its only the R32 ones.
    Keen to see results though
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  5. #95
    Jul 2012
    Launceston
    opinions on running Corvette C5 rims ?? With the front being a 17 inch and rear 18 ?? Just wondering whether diameter would be a problem, also differing weight of wheels?
    Spec would look something like:
    17 x 8.5 205/45 Front
    18x9.5 225/40
  6. #96
    Quote Originally Posted by waddz View Post
    18x9.5 225/40
    Yes to corvette wheels
    Doing double staggered is all about the tyre sizes. Its a tricky combo of what works, and what looks right.
    Check out bflats polo on the modenas for inspiration, wheel and tyre sizes not applicable for mk4, but shows it can be done
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  7. #97
    Mar 2011
    Dandenong, VIC
    Car: VW Bora v6
    Wheels: Rays Engineering / Volk Racing Group C
    Front: 17x9 et37( after 16mm spacer) 225/45r17
    Rear: 17x9 et38(after 15mm spacer ) 235/45r17
    Fenders Rolled: front yes
    Fenders Pulled: nope
    Camber: standard crazy bora 4-mo camber
    Suspension: Fk Ak street's
    not good fitment or anything but thought id post it up
    -2003 Vw Bora Vr6 4-Motion - Back From The Dead LiNk tO PhOtO Thread
    -1993 Nissan Nx-R , SR20DE+T Project.
    -1993 Kawasaki ZZR250 (grey import)"The StreetFighter"
  8. #98
    Quote Originally Posted by Neroo View Post
    I liked it! This thread is all about what does and doesn't work on a mkiv, doesn't have to be 'fitted' or 'slammed'. The more combinations and variations we can save the better.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  9. #99
    Dylan! do you know what stud offset are 17" porsche cup wheels?
    SKŪRANTIGADIRBIP
    MY01 MkIV Golf V6 4Motion
    MY00 MkIV Golf CL VR6 swap
    MY03 MkIV Golf GTi ,MY02 MkIV Golf 1.6SR
  10. #100
    Eastern suburbs of Melb
    About 60
    Sent from my GT-I9505 using Tapatalk 2
