Page 10 of 13 FirstFirst ... 89101112 ... LastLast
Results 91 to 100 of 124
Thread: Operation Bora Body
  1. #91
    Thats not too bad for the strip! im currently in the process of straightening mine back up
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  2. #92
    Jul 2010
    Elanora Heights, Sydney
    New headrests. Previous owner lost them, I've been looking for these since I bought my car.
    Another pic of my racks.
  3. #93
    Jul 2010
    Canberra , ACT
    imagine how hard it would be to find them in beige .. looks awesome !
    VW BORA 2003 V6 4Motion
    Volkswagen Golf MK3 1997 CL 1.8L
    Rammstien + Autobahn + Volkswagen = Leben !
  4. #94
    Jul 2010
    Quote Originally Posted by Golf-Sam View Post
    Thanks!
    Fixed my rear LHS strip today;
    Also tok this. Not sure whether to put the Oettinger 'Sport' grille back on or not. Better decide before I fill the hood notch.
  5. #95
    Nov 2006
    Largs Bay, S.A.
    Quote Originally Posted by PranK View Post
    Nice rack(s)!
    - someone had to say it!
  6. #96
    Nov 2006
    Largs Bay, S.A.
    Does anyone know if the Bora lower front valance fits the Golf?
  7. #97
    Jul 2010
    This update has been a long time coming. I umm'ed and aah'd about writing it for ages.
    Last October we had a catastrophic failure.
    Operation Bora Body-20151110_190936-jpg
    Operation Bora Body-20151110_195726-jpg
    What happened was ...
    I noticed a bit of steam coming from under the bonnet. It was a hot day and I was in traffic, at first thought I was just over heating. Then I smelled the oil. I pushed the car a little bit to get it off the road and when I checked under the bonnet there was just tonnes of sludge coming from the expansion tank. Everything was boiling and it was 50% oil.
    Note: What I find out in the future is that my temp sensor was broken (so temp on the dash was fine) and also my radiator fans weren't turning on. Explains a lot about how it happened.
    The car went to a local mechanic for analysis. They determined that my oil cooler had ruptured internally and, because of the flow of the water, the oil had literally been sucked out of the engine and into the cooling system.
    They suggested I sell the car for scrap, and I almost did.
    Then, I decided to give it a go myself and see what I could do. My main concern was that the engine had no oil at all and I didn't know if there was internal damage.
    Anyway, I had an ECS cooling system refresh kit that I'd been meaning to fit;
    Billet Gruvenparts crack pipe
    Thermostat, thermo housing and seals
    Temp sensor
    So, those along with the new Oil Cooler and a new bellyfull of nice oil and she started, first go (after several months).
    Operation Bora Body-img_20160316_160729-jpg
    Of course, the cooling system was full of gunk. I did 5 or 6 flushes, then stupidly added my G12++ as I thought it was clean enough.
    Also, I was finding it hard to open and close my expansion tank lid. Seems there was a reason for that.
    Operation Bora Body-20160725_202815-jpg
    The car was running. But there were a few things still wrong with it, mainly that it was now 3 months out of rego.
    Which meant new plates. This means that the car was no longer matching numbers (I know its not a classic, but I liked having the original plates).
    Operation Bora Body-img_20160630_162000-jpg
  8. #98
    Jul 2010
    So, it was time to focus my attention on the horribly clunking front drivers suspension. I was pretty sure it was the strut top mount, so I bought a new rubber mount and bearing.
    Seems it was a little bit worse;
    Operation Bora Body-20160806_151041-jpg
    Operation Bora Body-20160806_151105-jpg
    So, thats now in and much much better. BUT (and maybe a q for dylan if you read this) I wasn't able to torque the nuts on the strut, they tightened all the way up to the top of the strut. That didn't happen last time.
    Also, I replaced the ABS/G sensor behind the glove box. The braking problems I've been having since I bought the car (early ABS engagement) were gone!! OMG it pulls up so well! Its *never* braked like this!
    But, then my reco sensor died, so I bought and fit another reco sensor just this last week and so far so good. ($500 new or $140 reco.)
    Again, I can't explain how much better my brakes were after the sensor fitting. The ABS actually works but waits till there is a skid, which is not what it did before. As it is a lateral sensor, my theory is that it thought the car was travelling faster than it was, hence the early ABS.
    If you need to replace this sensor, take the glove box out, its much easier.
    So, now we're at current day.
    The drivers side wheel is making an absolute racket! The guide bolt snapped off inside the disk and while the disk is on centered (no wobble) I think I may have bent the dust shield so will check that over the weekend.
    ALSO, I found that my fans have not been working. I can make them turn on and off by bypassing the switch, which is good, it means they work! So, considering I need to drain the (still mud-like) coolant from the radiator to replace the switch, I bought myself a 2nd hand radiator, new O-Rings, new switch and 2 new bottles of G13.
    So, this weekend all those things will go in. I'm a bit excited about this.
    Also, I bought all the bits to build the fan-saver resistors fix thing. So, I'll put that in at the same time.
    Once all that is done I'm hoping the car will be happy. If it is, then I'll start to move into a preservation/restoration mode. I'll make sure gearbox and haldex are ok and just try to maintain things. I don't think anything else is really 'broken' as such. She's done 240k now, I'd love her to reach over 300k.
    I also have a little Mazda SP23 now also, I'm hoping I can keep the two for a bit longer so I have no real pressure on these weekend fixes. I don't need it on Monday. Thats a big help.
    Ok, I think you're all up to date.
  9. #99
    Jul 2010
    Quote Originally Posted by RolfGolf View Post
    It does not.
  10. #100
    Nov 2015
    Hobart, Tasmania
    Far out, you've had a battle. How di you rate the ECS coolant refresh kit? Which one did you get.
