It is the same thread, upon request I changed the title. Please ask questions in another thread though as this thread is meant purely for specs, not questions.
Factory Ride Heights: (Measured from rim-centre to wheel arch)
Standard running gear: 366 +/-10mm
Sports running gear: 351 +/-10mm
Heavy Duty running gear: 381 +/-10mm
Gavs.
My tdi is 350mm at the front and 380mm at the rear. I wouldn't mind 380 at the front the same as the rear. I need ground clearance for my daily drive up and down the Bruise Highway in CQ. Any ideas why my car is on a slant? Also I'm running 14" rims with 175/65 tyres. Next tyres will be 185/70 for extra height.
Neil
'11 Polo TDi auto, White, Sunroof
'91 Transporter syncro camper
Its the way it's designed by stock - the back always has more clearance to compensate when you load it up with stuff.
The gross weight for the car is about 1500kg (tare is 1080 average). 2 people in the front (140kg), 3 people in the back (210kg) and about 150kg in the boot for goods - most people lower the car so that the back doesn't sit so high because having bags of concrete in the boot to keep it low is bad for performance
You might struggle to find raising springs for these cars though, they are not exactly attracting 4wd owners...but then again you could look at the springs from a cross polo
Anybody know the weight of the polo range? the h&r springs are either up to 929kg or over 930kg.. I have a 77tsi 4 door sports MY12
Setup: Springs, Eibach Pro-Kit/Sportsline
Wheels Front and Rear: Team Dynamics Pro-Race 1.2 Anthracite 8 x 18 ET35 5x100 57.1DB
Tyres Front and Rear: Khumo 225/35
Arch height to ground (to centre hub) Front: 625mm (328mm)
Arch height to ground (to centre hub) Rear: 643mm (343mm)
Not as low as I would like but NO TYRE RUBBING and less stress on std. dampers + improved ride quality and handling.
Body down from std GTI ride height: 33mm rear and 16mm front
Attachment 6466
Attachment 6467
Attachment 6469
Last edited by car_nut; 05-12-2013 at 09:15 AM. Reason: Remeasured and since fitting 2 weeks ago it has dropped slightly, either that or I measured wrong
2015 Polo GTI with DA pack : Milltek Turbo back exhaust | DD spacer | JB1 | VWR Turbo Intake elbow and intake hose | BMC panel filter | KW Street Comfort coilovers | Whiteline adjust. endlinks | Harding DSG Perf. tune | Wagner Intercooler| Dotz Mugello 17 x 8 32ET
Car: Polo TSI (Comfort)
Setup: KW Street Comfort Coilovers
Wheels: Advan RS 17x8.0 ET37 (Dark Gun Metallic)
Tyres: Continental Premium Contact 2 215/40R17
Arch height to ground Front: 624 (+/- 1mm)
Arch height to ground Rear: 629 (+/- 1mm)
Thanks to Damien (Gusman) for helping out with my choice of coilovers. Couldn't be happier at the moment. Have rebound damping dialed in at halfway between soft and hard. There is room to go lower but my brief for the Polo is OEM+ setup with practicality. Love this thread as well as it helped me out in deciding my setup. Let's keep it going
