Page 1 of 7 123 ... LastLast
Results 1 to 10 of 61
Thread: Polo Project
    Mar 2009
    Melbourne CBD
    Polo Project
    Hi guys, i just bought a Polo GTI and i plan to make it go VROOM!
    So here is what i am getting installed..
    Ordered and waiting K04-25 CHRA and other stuff in the kit (fuel injectors and etc)
    Ordered and waiting for PSS 9 coil-over's from Blistein
    Looking for either the Porsche 2 piece slotted brakes or the R32 brakes which i wanna get slotted too.. not sure.. Feedbacks?
    Custom tuning for the bigger turbo
    What is on at the moment is an ECU upgrade, Full Milltek, upgraded CAI, Forge intercooler, Upgraded front rotors and competition pads, some work on suspensions (forgotten), silent blowoff valve, stage 3 clutch kit (to handle K04-25 CHRA) and a Limited Slip Diff.. There are some other stuff... I just can't remember..
    Will have to run semi-slicks when project complete..
    Please give me feedback as to what i am missing or should also do to my new pocket rocket!
    ALFIE
    Nissan Elgrand E50, Polo GTI and Evo 6RS Track car
    Mar 2009
    Melbourne CBD
    p.s got 170ish Kw at the flywheel atm.. with the stock k03 turbo
    ALFIE
    Dec 2008
    Curitiba/PR, Brazil
    Don’t forget the aluminum flywheel!
    SILVER TEAM
    Mar 2009
    Melbourne CBD
    Lol forgot mate.. I have the chromeolly lighted flywheel installed atm... Thanks buddy... WHat else can i do? I won't lie, this idea came from your polo..
    ALFIE
    Aug 2008
    You've done the sort of things I want to do to mine. Who are you getting to do the tune once the turbo is installed. I have a GT28R sitting in my garage but unable to find anyone that can do a custom tune on the Polo's (I don't want a generic tune I actually want a tune customized to my car on the dyno, similar to open ecu).
    Cheers,
    John
    Feb 2008
    ACT
    Very keen to hear how your project gets along - your mod list is pretty much what I've been working towards on my car (MY07 Polo GTI).
    I'm running the PSS9s on my car - it's a great setup though I must admit I don't really use the adjustable part of the suspension at all. I set them to the firmest setting shortly after getting them installed and I haven't changed them since (though if I knew more about which tracks would work best with softer settings I'd probably try that out).
    As for brakes, I went down the APR 323mm path. The biggest consideration with that setup is finding wheels that will clear the calipers - I believe that APR now sell some lightweight wheels that will do the trick but I ended up with several sets of Audi TT wheels which work well but are very heavy. I also found the pads that came with the kit were not up to the task when it came to regular track use, but after replacing with some Ferodo pads the brakes are now fantastic.
    I'm very keen to hear how you go with the K04 / LSD combination - I've been holding off on the bigger turbo partly because I don't think it'll be much good without an LSD to get the power to the ground. Once I decide to go that way I think it'll be a case of installing K04, LSD, clutch and flywheel all at once.
    Decent R-Spec tyres will make a huge difference on the track - the best I have found for this car are Kumho V70A 205/40 17. I'm running the hard compound version at the moment so they've lasted reasonably well (probably about 8 full track days including the NSW Dutton last year).
    Please keep us updated with your project build!
    Jun 2008
    Perth
    Quote Originally Posted by Black R36 Sedan 09(alfie) View Post
    Light flywheel (14lb) or super light flywheel (7lb)?
    Jun 2008
    Perth
    Quote Originally Posted by Plautos View Post
    Hey Plautos what is the weight of ur flywheel? I am looking at the ECS 7lb.
    (sorry if off topic)
    Dec 2008
    Curitiba/PR, Brazil
    Fidanza claim 11lb.
    With the clutch monted 8kg.
    SILVER TEAM
    Quote Originally Posted by JCM308 View Post
    mate Unitronics do 'big turbo' software
    Bug_Racer on here is the Aussie dealer for them. PM him and ask
