Page 1 of 24 12311 ... LastLast
Results 1 to 10 of 236
Thread: has anyone upgraded their stereos?
    Dec 2006
    sydney
    thinking about upgrading mine, no idea what to get though in terms of what double din to get thats good or is it worth upgrading speakers aswell.
    does anyone actually know what system is in the gti allready in terms of model and what speakers are used?
    if anyone has upgraded theirs and has some piccies on offer that would be great.
    cheers
    Jul 2006
    melbourne
    Thinking of upgrading too thanks to my volume knob that keeps turning itself up and now my speakers are getting scratchy.
    gtigrl want to go faster
    2006 Polo GTI
    Sep 2006
    Tweed Heads
    Quote Originally Posted by gtigrl
    Hoyhoy.
    Ah, the volume knob. Yes I use to think the knob was wierd & changing volume. But try playing with the knob [volume] when the car is sitting still & you'll find tiny notches, if you leave it in between notches at the desired level, you should find the volume will stay steady.
    Hooroo.
    Nov 2006
    Actually, the stereo has a feature which progressively increases volume with speed. You can set various levels (rates of increase) using the tuning knob
    Sep 2006
    Tweed Heads
    Quote Originally Posted by Timbo
    Hoyhoy.
    Learn something everyday.
    Hooroo.
    Sep 2006
    Tweed Heads
    Hoyhoy.
    gtigrl--------gtigrl.
    This Timbo, he's on the ball. I did also have problems with vol. knob half way between notches.------- But like Timbo says try the GALA setting [booklet No. 3.4_ page6] in the manual. Tricky stuff, first hold in the tuning knob, you will get GALA with numbers 1 to 9 by turning the knob left or right, which will give you varying volume ratios per speed.
    Modern gadets with my vintage brain. Just too much.
    Hooroo.
    Aug 2006
    Skye, Victoria
    Can be done, i'll try and dig up some photos of a couple we did at my previous job.
    Jul 2006
    melbourne
    yeah I keep finding that with increased speed comes increased happiness and volume, particularly with the rock and roll genre
    2006 Polo GTI
    Nov 2006
    After my own heart No doof doof
    Dec 2006
    Quote Originally Posted by Veee1.8t
    cheers
    Vee in it is a double din blauplankt head unit with phillips 6" front splits. I got mine done by some guys in Brisbane "Northfield at Mcgregor" did a really good job except for the part i mentioned in my other post. I would say if your doing one do the head unit first single din is fine and they used a pocket from a Mazda 3 for the other space. Also if you do consider speakers factor in some Sound deadining as the door trims are metal (bit tinny without the stuff) and forget mounting an amp under your front seats cause there is a metal bump in the middle which meant my amp is mounted in the boot.
    When i get a chance pics will be posted.
    Hope that helps
Similar Threads
  1. upgraded fuse box? any idears
    By finemk1 in forum Mk1 Golf
    Last Post: 14-08-2006, 10:26 PM
