My 118TSI takes about the same time.
Don't wait, don't care - drive it like you stole it
50 degrees C
Between 50 and 80 degrees C
Between 80 and 95 degrees C
More than 95 degrees C
It all depends if I'm in a hurry or not
Is it just me or does the GTI take a long time to warm up?
I timed it the other day. These times are while driving, not sitting and idling. Ambient temperature was 10C according to the car. Car is a DSG. Driving on 60km/h roads for 15 mins and then on to the freeway.
Time till coolant reaches 90C: ~8 mins
Time till oil reaches 90C: ~18 mins
18 mins is a long time to reach optimal operating temperature!
MY20 Golf GTI TCR
MY20.5 LR Defender P400 HSE
TDI takes even longer — coolant temp can take up to 20 minutes (occasionally more) on a cold morning.
Makes the heater somewhat of dead loss...
My old Accord would take less then 5 mins for coolant to warm up.
It's annoying to wait so long before driving the car hard. I rarely drive any where more than 20 mins anyway.
Yeah most VW's run coolant at about 110 C (depending what engine) and only show 90 C on temp guages to not freak out car owner out as 110 C looks way to high on guage and people will think car is over heating
I've been showing great restraint in waiting for the oil temperature to get to at least 80 degrees C before giving the car a bootful, and was wondering what others do?
About 1 min or so after cold start. I don't worry about oil temp. Pressure is far more critical.
Those that do are only worried because they have an oil temp gauge...
Babying an engine is one of the worst things you can do to it..
According to the 118TSI owners manual maximum RPM should only be used when the coolant temperature is in the 'normal' region (above 70 degrees). I also wait for the oil to get above 55 deg which happens a later as oil temperature lags behind coolant temperature. This is becasue the coolant is picking up heat from the cylinder heads. Oil temperature is a better indicator of the temperaure of the moving parts. It is common practice in aviation for and engine manufacturer to specify a warm-up to achieve a minimum oil temperature before takeoff power and RPM can be used. There are a couple reasons behind this that I am aware of:
a) Different parts of the engine warm up and therefore expand at different rates so the warm-up allows time for heat to distribute more evenly and clearances of moving parts to be within limits before high loads are applied.
b) At lower temperatures the oil is thicker and although the oil pressure looks healthy, its flow rate is reduced which can result in insufficient oil flow for some wear surfaces. The viscosity of the oil is selected by the manufacturer such that it provides optimum oil pressure AND flow rate at the operating temperature. Too cold and there isn't sufficient flow rate, too hot and the pressure is insufficient.
