Results 1 to 10 of 16
Thread: MK6 overhead console illumination
    Hey all,
    just had a quick question re the overhead console on my MK6, my sunroof buttons dont lite up!
    on my MK5 they did and ive seen the diy to change the newer style illuminated knob over but my console seems to be a bit of an odd ball one as all the parts catalogs i have seen show a different type of console ( more like the mk5 one)
    has anyone else got a MK6 with sunroof and alarm??
    B6 Tdi Wagon - Reflex silver, heated memory leather, sunroof, 300k+
    MK7.5 Alltrack 132tsi Premium - Tornado Red, Sound & vision, Sport lux packs + retrofits
    Jan 2012
    Epping, NSW
    My console looks like the photo there, except the rear view mirror has sensor for rain& possibly light.
    Manual MY12 RB Golf R | Bluefin Stg2 | Milltek turbo-back
    yeah mine has the rain light sensor just cant see it in this pic
    Nov 2009
    That's the standard Mk6 w/sunroof overhead console. Mine's exactly the same (except for colour). And no, the sunroof button does not illuminate - it's a shocker from an ergonomics perspective. Amazed that VW let it out of the factory that way TBH.
    I just remember "7 clicks" to open, "7 clicks" to close.
    Sep 2009
    ACT
    Quote Originally Posted by AdamD View Post
    Same in the R. Generally the German design is really thoughtful and clever. No illumination on the sunroof dial is a clanger.
    Current ride - Golf R 7.5 DAP, Sunroof, Dynaudio, DSG
    hmmmm, i thought maybe mine had a fault.. damn!
    im going to try swapping it out for a MK5 illuminated one (the button is interchangeable)
    or one of the touareg ones
    Jan 2012
    Epping, NSW
    Yeah, the main thing I don't like about my sunroof button is that there is no tactile feel or difference when you reach the centre position when closing. Often I think I have returned it to centre, only to get out the car and see the roof is tilted up a small amount. Of course I then just long hold the remote lock button to get it closed, but still....
    Let's face it, with that tiny white dot/stripe you can really only tell its position if you stick your head directly under the button, else parallex error trying to "guess" that you think it is centred.
    Even my 1994 Pulsar SSS was more user friendly!(let's not mention the massive boominess the Golf has vs the Nissan when slid back...the Nissan didn't need that spring loaded section, there was no major boom at any slide back position, nor did you have to crack rear Windows open to bear with it).
    there is a very slight difference when you turn it to centre but not by much, and really not by enough my mk5 switch had a much better feel to it... ive ordered one to swap it out so we shall see!
    update on this thread, I bought a illuminated switch from a MK5 and sure enough its a straight plug and play swap.
    drop the light console down, squeeze the retaining tabs on the back of the sunroof switch then just slide it up & out, install the new switch in reverse order.
    The MK5 switch has a MUCH better feel/action to it and you can very clearly feel where the "centre/closed' position is.
    I'm still yet to figure out how to wire up the illumination in the switch but otherwise it works perfectly
    when i get some more time i will pull apart the stock mk6 switch and see if the internal cogs (that govern the 'clicking/notches) are able to be changed over from the mk5 switch, given the rest of the design id say this will be as easy as changing the physical grey mk6 knob onto the body of the mk5 switch
    Jan 2012
    Epping, NSW
    Thanks for the update. But surely putting mk6 knob onto mk5 switch defeats the illuminated purpose for doing this, as the illumination would be a small LED shining through a semi transparent section which the mk6 knob won't have? I assume the wire connector is the same and you just require a repair wire it whatever it is called to break out the third? 4th? blank and there are a number of places to tap for power up there (permanent illumination), or dig around for a lighting switch power source.
