Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: How to Disable ESP
    Aug 2012
    Perth WA
    How to Disable ESP
    Engine Computer Hackers Show You How To Disable The VW Golf R's Stability Control
    Above is a link on how to disable ESP on a Golf R using VCDS.
    Remember Caveat Emptor.
    Mar 2008
    Sunshine Coast
    How to Disable ESP on Golf R
    R's post June 2011, you can disable it much more easily though cant you ?
    Hold the button down until both are off
    8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
    Oct 2010
    Melbourne, VIC
    The console doesn't actually let you totally disable ESP - it just puts it in a milder setting.
    Love to hear from someone who tries this mod
    Resident grumpy old fart
    Mar 2008
    Sunshine Coast
    Quote Originally Posted by kaanage View Post
    Really ?
    I thought MY12s post June 2011 it was a new system that allowed it totally off
    For track, value is there but no value whatsoever for road use
    Nov 2009
    Hills District, Sydney, NSW
    Quote Originally Posted by Candyman View Post
    Really ?
    What he said
    Apr 2010
    Link: Golf R ESC DIY
    Don't see the point of it in my case since I'll never be on a track and FWD cars will just understeer.
    Mar 2008
    Sunshine Coast
    That is for the US R though ?
    Jan 2009
    brisbane queensland
    So will this work on a 2011 or is it just post 2012 and us models???
    YAY I got my R!!!! White, recaro seats, 19" wheels, bluetooth, reverse camera
    Nov 2009
    Really ?
    Not quite. The ESP can be put into a suspended state, but if you touch the brake while you're having a moment, the car will automatically re-enable it. This is a safer compromise for road use, but still doesn't make the car 100% track-friendly. In the US, they don't even get that feature - it's ESP-on all the way.
    The mod being discussed on VWVortex will disable the ESP completely - it won't be re-enabled by a touch of the brakes. Only by switching ESP back on or restarting the car will it kick in.
    Nov 2009
    Quote Originally Posted by shinygti View Post
    Apparently you need this specific ABS Controller hardware, and this (or later) software:
    Quote Originally Posted by VWVortex
    Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
    Component: ESP MK60EC1 H31 0121
    Revision: 00H31001
    Apparently a part number ending in BG may also work in some cases. However, these parts appear to be specific to late 2011+ build Golf Rs, GTIs, TSIs and TDIs, Skoda Octavia, etc.
    Several Golf GTIs with this same ABS Controller have also accepted the coding change and will allow the ESP to be disabled. AFAIK it's just US and Canadian cars that have been coded successfully thus far.
