We ended up trading ours in after 4 engine failures for a new golf. So far there has been no issues!
Resident grumpy old fart
Hi everyone,
I need help!!! I have a 2010 Golf 118TSI with 107000km on the clock (ie just out of warranty). It has always been serviced at the VW dealership. About a month ago the catalytic converter light came on and the car started idling rough on startup. On one occasion the car actually stalled on startup and also had considerable loss of power when driven. I took it to the dealership and they diagnosed it with "bad fuel causing an engine misfire", cleared the code and said to come back if it happens again. A few weeks later the light came on again, it was still misfiring and back to the dealership I went. They said the engine has a cracked piston and they would need to replace it (possibly all four? I was so horrified I tuned out a bit) at a cost of $6000. VW goodwill have agreed to pay for parts and 30% of the labour costs which would leave me $1900 out of pocket.
So I am completely freaking out. How do I get VW goodwill to cover the entire cost?? I've done a lot of research and clearly there is a fundamental flaw in the these engines that is causing them to fail. How can VW expect me to shell out nearly 2 grand to repair the engine when so many have died already??? I think it has had that 24S4 software upgrade but the damage must have already been done by that point...
Another question is: if they replace all the pistons, will the engine just die again down the track?? Has the software upgrade actually fixed the issue or is it just a bandaid?
And I was also wondering, is replacing the pistons just a dodgy fix?? Should they be replacing the whole engine?
Thanks very much for you help.
What state are you in (not state of mind ) if your in Sydney I can point you in the right direction
Hahaha yeah no doubt you already know my state of mind!! I am in NSW - Hunter Valley. Thank you!
From my time at dealership level, the first offer of goodwill is the only offer of goodwill. It's not known to be negotiable.
What fuel do you use?
Should you choose to go ahead with the engine rebuild, I'd strongly recommend using 98 octane premium from here on in.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
If you've only been communicating at dealership level then you could escalate direct to VW Customer Service.
Keep in mind that while your factory warranty may have expired, you still have a statutory warranty which basically says that an item has an expected lifespan. I'm sure when you bought the car a reasonable person wouldn't expect a modern, quality product such as a VW engine to expire in 4 years/100,000km if it had been serviced properly. As you state you've had all your services done at VW you should be more likely to have your claim accepted.
I would push a bit harder, document your communications & be firm & polite. Do your homework. Have a read about statutory warranties at the ACCC website as many retailers haven't a clue what they are or what they mean.
Thanks for all the advice guys - excellent news today! VW goodwill have agreed to pay the entire repair bill ($6000) in full!! I didn't even have to kick up a stink, I was just as nice and courteous as possible and it actually worked. I am incredibly relieved and honestly felt like kissing their service manager.. So so happy!! Im obviously still very concerned about VW reliability (especially the reliability of this car) but I've got to say I'm incredibly impressed with their service.
Has anyone had any experience with these cars after something like this (cracked piston)??? The car will have a 2 year parts and labour warranty on the engine now, but should I be worried that it will just die again in another 2 years? Has updating the software (ie through the service campaign) actually resolved the engine failure issue in these golfs?
I'm strongly thinking about trading it in for a (possibly) more reliable car, but I can't really think of a car I would prefer more than this one (without spending a lot more money).
Thanks again for the advice!
