Results 1 to 10 of 10
Thread: Tyre pressure question - 2013 polo gti
    May 2013
    Hervey Bay, QLD
    Hi guys
    Not sure if anyone has answered -looked but found nothing specific...
    The placard says about 270(rough conversion 39) but it seems high to me...
    What tyre pressure for the polo gti do you guys recommend? 214/40/17 tyre size
    Harry
    MY13.5 Red Polo GTI
    Harry
    MY15 RED Polo GTI 6C - with DA Pack
    Mar 2013
    Brisbane QLD
    VW spend millions of $$ on working out whats' the best pressures for the tyre to car ratio, I would stick with what the fuel cover sticker says personally..I see a lot of over and under inflated tyres and the are ruined. Keep them at the recommended amount and then keep checking them every 5,000km or so if they are wearing on the middle of the tread more then reduce the pressure, if they are wearing more on both outside edges then increase the pressures...VDUB...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Jan 2009
    blankedy
    39 sounds high for stock, but is what I would run my fronts at for optimum life vs handling.
    I tend to run my rears a bit lower as there is less weight to keep them flat on the road, say 36...
    May 2013
    Hervey Bay, QLD
    Cool... Thanks... Might give a few setting ago and see how it drives
    Much appreciated.
    Harry
    MY13.5 Red Polo GTI
    Harry
    Jun 2011
    Sydney NSW
    Quote Originally Posted by Harrydhillon View Post
    Hi guys
    Low profile tyres need higher pressures because they have less air in them to provide cushioning. There's less sidewall to cushion you from bumps.
    Jan 2009
    There's no real reason to deviate from the manufacturer's instructions or specifications unless you wish to alter the car's dynamic behaviour.
    May 2013
    Hervey Bay, QLD
    Ok..thanks... Will stick with what's recommended
    However...can anyone delete that comment that's sounds like spam??
    Harry
    MY13.5 Red Polo GTI
    Harry
    Jan 2009
    blankedy
    Has been reported, a mod will get to it.
    May 2013
    Hervey Bay, QLD
    Thanks.... not sure if I could report such thing and how...
    Harry
    MY13.5 Red Polo GTI
    Harry
    Pacific Paradise QLD
    Harry
    MY13.5 Red Polo GTI
    Use the little triangle Bottom left
